The Review tab is enabled once comparison results are available. In this tab, you can control the comparison review mechanism options. From the Review type list, specify the type of graphical review to apply by selecting one of the following options:
Select this option if you do not want to apply any graphical review.
Select this option if you want to generate a visual representation of the comparison results graphically.
When you select Comparison from the list, the following supplemental options are enabled:
From this list, specify how to display the results of the match types by selecting:
Displays all of the match types by grouping together the matched/overlapped as matched and the intersected/unmatched as unmatched.
Displays all of the match types by their defined colors.
To control the display colors of each of the match types for both the source (left) and target (right) entities, click the color swatch and then select a new color from the box.
To control which match types display in the graphics area, select the check box next to each match type you would like to display. If any entity is part of two match types, then the "worse" type takes precedence.
If you would like to reset the colors to their default values, click Reset Colors.
From this list, specify whether the source entities, target entities, or no entities at all will be drawn transparent. The entities displayed that are not part of the comparison operation will always be drawn transparent.
From this list, specify how transparent entities will be drawn by selecting:
Displays transparent entities in their default color.
Displays transparent entities in the default Altair HyperMesh gray color.
Select this option if you would like to generate a contour plot that shows the distance of the target entities from the source entities. This option is not available for CAD-CAD comparisons. When you select Distance from the list, the Maximum distance field becomes enabled and you can specify a maximum value to display in the contour legend.
See Also:
Comparison Tool
Generate
Results
Sets
