Engineering Solutions offers several meshing algorithms for lines/edges (1D), surfaces (2D) and volumes (3D) which can be accessed via the Mesh menu.
CFD has the following meshing capabilities:
Generate 2D meshes with or without boundary layers on planar or non-planar sections defined by sets/groups of edges defining closed loops. |
Get a clean, water tight shell mesh out of 2D mesh containing several intersecting parts and small gaps which do not need to be modeled. |
Create meshes or re-mesh existing meshing interactively or automatically on surfaces or groups of elements. |
Create a contour plot of the existing distributed thickness values using the Contour panel. |
Boolean Operation |
Connect intersecting 2D elements. This tool works for triangular as well as quadrilateral elements. |
Generate hybrid grids, containing hexa/penta elements in the boundary layer and tetra elements in the core or fare field. |
Verify the basic quality of your elements and to verify the geometric qualities of those elements. |
Create Single Component |
Opens a dialog to create a single component. |
Create CFD Components |
Functionality to define the standard CFD collectors. In the dialog, the commonly used collectors names, such as inflow, are pre-selected. Components can be added or removed from the list and a multiplier for each component can be defined. By clicking Create the selected components are created and appear in the Model browser. |
Delete data from a model database, preview and delete empty collectors and preview and delete unused property collectors, material collectors, or curves. |
Detach elements from the surrounding structure. |
Determine the distance between two nodes/points or the angle between three nodes/points, or to change distances or angles. |
Create a surface and/or mesh by dragging a series of nodes or lines, or to create elements by dragging selected elements. |
Find the free edges in a group of elements, find "T" or discontinuous connections in a group of elements (any edges connected to three or more elements), display duplicate nodes and equivalence duplicate nodes. |
Perform automatic cleanup of 2D elements based on the element quality criteria from the Quality Index panel or a separate criteria file. |
Hand-build, combine, split or modify elements. |
Create and modify elements by offsetting from a mesh of plate or shell elements. |
Select and change existing element types. |
Find the free faces in a group of elements and operates in the same manner as edges, but in 3D. |
Calculates features (corners) in the current model and displays them by creating one dimensional plot elements or feature lines. |
Fuse |
Connect close proximity, overlapping, and intersecting parts. |
Creates a hex-core mesh inside any arbitrary volume defined by a surface mesh consisting of 2D first order elements: tria3 and quad4. |
Create hidden line plots of the displayed structure. Also contains the Clip Boundary Elements tool, which allows you to visually sweep the cutting section for greater viewing clarity. |
Hole/Gap Fill |
Mesh holes, gaps, and patches. |
Check for penetrations and/or intersections of elements. |
Create a two or three dimensional surface and/or mesh or elements by dragging nodes, lines or elements along another line. |
Create a chain of one dimensional elements such as beams along a line. |
Create solid elements between two groups of plate elements. |
Obtain the mass, area and/or volume of a selected group of elements, solids or surfaces. |
Mesh Controls |
Define one model specific mesh setting, as well as an unlimited number of local mesh settings. |
Associate nodes to a point, line, or surface/solid face; move nodes along a surface; place a node at a point on a surface; remap a list of nodes to a line; or project nodes to an imaginary line passing through two nodes. |
Create nodes using a wide variety of methods. |
Display the normal of an element or surface, adjust the orientation of element normals and reverse the normal of an element or surface. |
Create a square, planar surface and/or mesh in a user-specified plane or a surface and/or mesh bounded by planar lines. |
Reorganize your database by copying or moving data (entities) among collectors or includes. |
Generate a grid containing rotational and/or translational symmetric boundaries, for example rotating machinery. |
Project |
Project data entities to a plane, vector, surface, or line. |
Calculates a single value to represent the quality of the displayed shell (2D) model. |
Quality Index Calculations |
The Quality Index value is a function of twelve criteria with user-defined weight factors. |
Reflect portions of a model about a plane, changing the selected portion into a mirror image of itself. |
Renumber entities. |
Allows nodes to be replaced with other nodes. |
Rotate entities around an axis in space. |
Create surfaces and/or meshes of plate elements from nodes, lines and/or line segments, in any combination. |
Increase or decrease an entity’s dimensions. |
Create a skin surface and/or mesh from a set of lines. |
Create a mesh of solid elements in a solid geometric volume. |
Create meshes in a pentagonal or hexagonal volume defined with edge lines. |
Create a surface and/or mesh or elements by spinning a series of nodes, a line or lines, or a group of elements about a vector to create a circular structure. |
Create a shell mesh and/or surface. |
Split plate or solid elements. |
Fill an enclosed volume with first or second order tetrahedral elements. |
Improves the quality of a tetra mesh with respect to several element criteria. |
Move entities in a single specified direction. |
Creates a hexahedral mesh inside the volume. |
