»Click here to display Table of Contents« »No topics above this level«
The Temperature dialog allows you to define and edit the *TEMPERATURE card. To open the dialog in the Load Step window, select Temperature from the tree and a load collector from the Load collector table.
The dialog contains three tabs:
Load collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
