Engineering Solutions
Load Step: Temperature: Delete Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Delete tab allows you to delete boundaries and other loads from Engineering Solutions. There are three options:
All loads in current collector
The Delete button deletes all the loads from the current load collector.
All 'Temperature' in current collector
The Delete button deletes only *TEMPERATURE loads from the current load collector.
By selection
The Pick Loads button opens the Load Selector panel.  Pick the loads you want to delete and click proceed.
The corresponding Reset button resets the selected loads.
The Delete button deletes the selected loads.
See Also:
