Engineering Solutions
Load Step: RADIATE: Define Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Define tab allows you to define *RADIATE cards on individual elements or geometry (surfaces) as well as on element sets.
step_mgr_radiate_define_elem_geom
For Define RADIATE on:, the following options are available:
Elements or geometry
Element sets
The layout of the Define tab changes, based on your selection.
See Also:
Load Step: RADIATE
