Engineering Solutions
Load Step: RADIATE
Load Step: RADIATE
This is the first topic This is the last topic No expanding text in this topic
Load Step: RADIATE
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The RADIATE dialog allows you to define the *RADIATE cards on individual elements or geometry (surfaces).  You can also define the RADIATE on element sets.  To open this dialog in the Load Step window, select RADIATE from the tree and a load collector from the Load collector table.
The dialog contains three tabs:
Define
Delete
Parameter
step_mgr_radiate_define_tab
See Also:
Load Collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
