Engineering Solutions
Load Step: RADIATE: Define Tab: Elements or Geometry
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Define RADIATE on: Elements or geometry option allows you to define RADIATE on individual elements or geometric surfaces.  RADIATE loads created on elements have special graphical display in Engineering Solutions. Loads created on geometric entities like surfaces are automatically mapped to FEA mesh on export.  You can also map them using the Map Loads on Geometry button.
step_mgr_radiate_define_elem_geom
The Define tab for Define RADIATE on: Elements or geometry has the following buttons:
Define from Pressures panels
Opens the Pressures panel to create/update RADIATE.  It only allows you to define the reference sink temperature.
To create a RADIATE on elements, go to the create subpanel, select elems using the switch, pick the desired elements from the graphics, click nodes, pick two or three nodes from a face of a selected element, input the magnitude (ambient temperature), and click create.
To create a pressure on geometry, go to the create subpanel, select surfs using the switch, pick the desired geometry from the graphics, input the magnitude (ambient temperature), and click create.
Note:
Loads created on geometric entities are automatically mapped to FEA mesh on export.  You can also map them using the Map Loads on Geometry button.
You can also update an existing RADIATE from the update subpanel.
While you are in the Pressure panel, press the H key to view panel-specific help.
When you are finished creating or updating boundary conditions, click return and the Step Manager will be updated with the new loads.
Opens the Loads on Geom panel to map loads on geometry to FEA mesh entities.
Click the Map loads button to map all geometric loads in the current load collector to FEA entities.
Note:
You can also pick other load collectors by clicking the loadcols button and map loads in all of them together.
While you are in the Loads on Geom panel, press the H key to view panel-specific help.
When you are done, click return and the Step Manager will be updated with the new loads.
See Also:
Load Step: RADIATE
