Engineering Solutions
Load Step: Monitor
Load Step: Monitor
This is the first topic This is the last topic No expanding text in this topic
Load Step: Monitor
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Monitor option in the tree allows you to define the *MONITOR card.
The supported attributes are: Node, Node Set, DOF, and Frequency.
See the Abaqus online documentation for a detailed description of these attributes.  Click Update to activate the monitor attributes defined in the Altair HyperMesh database.
step_mgr_monitor
The following buttons are available on the Monitor dialog:
Pick node
Opens the node selection panel.  When you finish picking a node from the model, click return.  The Step Manager is updated with the selected node number appearing in the Node entry.
Create/Edit
Opens the Entity Sets panel. When you finish creating/editing the set, click return. The Step Manager is updated with the new set appearing in the node set list. For  the Abaqus solver, the set must contain one node only.
Update
Updates the Altair HyperMesh database with the data lines defined in the table and the parameters.
See Also:
Abaqus Step Manager Step Tab
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
