The File format option in the tree allows you to define the *FILE FORMAT card. This option is available when a standard Abaqus template is loaded.
The supported attributes are: File format and Zero increment.
See the Abaqus online documentation for a detailed description of these attributes. Click Update to activate the monitor attributes defined in the Altair HyperMesh database.
