Engineering Solutions
Load Step: DLOAD: Define Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Define tab allows you to define *DLOAD cards on individual elements or geometry (surfaces) as well as on element sets.  There are seven different DLOAD types available: default (Pressure), centrifugal, rotary acceleration, gravity, pressure in pipe/elbow, hydro pressure, and hydro pressure in pipe/elbow.
Only default (Pressure) type DLOAD can be created on an individual element or geometry in Engineering Solutions.  The other types are available only for element sets.
It is recommended that you use only one type of DLOAD in a load collector in Engineering Solutions.  If you need to use multiple types of DLOAD in the same STEP, define each type in a separate load collector and add them to the same load step.
You can define DLOAD on elements, geometry, or element sets.  For Define DLOAD on:, the following options are available:
Elements or geometry
Element sets
The layout of the Define tab changes, based on your selection.
See Also:
Load Step: DLOAD
