Engineering Solutions
Load Step: DLOAD
Load Step: DLOAD
This is the first topic This is the last topic No expanding text in this topic
Load Step: DLOAD
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The DLOAD dialog allows you to define the *DLOAD cards on individual elements or geometry (surfaces).  You can also define the DLOAD on element sets.  To open the dialog in the Load Step window, open Distributed loads in the tree, select DLOAD, and select a load collector from the Load collector table.
The dialog contains three tabs:
Define
Delete
Parameter
step_mgr_dload_define_tab
See Also:
Load Collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
