Engineering Solutions
Load Step: CFILM: Define Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Define tab allows you to define a *CFILM card on node sets only. Engineering Solutions does not support *CFILM on individual nodes.
The Define CFILM-Force/Moment on: Node sets option defines CFILM on node sets. The node set names are used in the *CFILM data lines instead of the individual nodes. Unlike Abaqus surfaces in Engineering Solutions, you can combine node sets with individual node IDs in the same *CFILM card.
Note:Loads created on sets are not graphically displayed in Engineering Solutions. Therefore, when you review a load collector in the Step Manager, only loads created on individual entities are highlighted. For loads defined on sets, the underlying nodes or elements are highlighted.
step_mgr_cfilm_define_tab
This dialog has a node sets menu containing a list of the existing node sets.  It also has a data line input table with the following columns:
Nodeset
The name of the node sets.  Node sets are added or removed using ab-step-man-right  or ab-step-man-left, respectively.
Area
The area associated with the nodes.
Sink temp
Reference sink temperature.
Film coef
Reference film coefficient.
For tips on entering information and navigating in the Define tab, see Step Manager Tab Environment.
The Define CFILM on: Node sets option has the following buttons:
Review Set
Reviews the selected node sets by highlighting them in the Engineering Solutions graphics.  Right-click Review to clear the review selections.
Create/Edit Set..
Opens the Entity Sets panel.  When you finish creating/editing the set, click return.  The Step Manager is updated with the new set appearing in the node set list.
ab-step-man-right
Adds the selected node set from the drop-down menu to the data line table on the right.
ab-step-man-left
Deletes the selected node set from the data line table.
Review
Reviews the selected node set in the data line table.  Right-click Review to clear the highlighted selections.
Update
Updates the  database with the data lines defined in the table.
See Also:
Load Step: CFILM
