Engineering Solutions
Load Step: CFILM
Load Step: CFILM
This is the first topic This is the last topic No expanding text in this topic
Load Step: CFILM
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The CFILM dialog allows you to define the *CFILM card on node sets.  To open the dialog in the Load Step window, open Concentrated loads in the tree, select CFILM, and select a load collector from the Load Collector table.
The dialog contains three tabs:
Define
Delete
Parameter
step_mgr_cfilm_define_tab
See Also:
Load Collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
