Engineering Solutions
Step Manager Tab Environment
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
Editable cells have a white background, unless it is the active cell.  You can input values using the keyboard in editable cells. Non-editable cells have a gray background.
Left-click in an editable (white background) cell to activate it for input. Click in an active cell to move the insertion cursor to the character nearest the mouse.
Press CTRL and the left or right arrow key to move the cursor within the active cell. Use the left, right, up, and down arrows to change the active cell.
Press BACKSPACE to delete the character before the insertion cursor in the active cell.
Press DELETE to delete the character after the insertion cursor in the active cell.
Table columns can be resized by positioning the cursor along a column border, pressing the left or right mouse button, and dragging the border to a new position.
In some fields, you can use the (…) button to open the Entity browser to select the entity for that field.
