Engineering Solutions
Load Step: Boundary
Load Step: Boundary
This is the first topic This is the last topic No expanding text in this topic
Load Step: Boundary
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Boundary dialog allows you to define and edit the *BOUNDARY card.  To open this dialog, select Boundary from the tree and a load collector from the Load collector table.
The Boundary dialog contains three tabs:
Define
Delete
Parameter
step_mgr_boundary
See Also:
Abaqus Step Manager: Load Step Dialog
Load Collector Dialog
Abaqus Step Manager Overview
