Engineering Solutions
Load Step: Boundary: Define Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Define tab allows you to define *BOUNDARY cards on individual nodes or geometry (surfaces, points, lines). You can also define the boundary on node sets. There are five different types of boundary conditions available:
Boundary types
Abaqus keyword
Default (disp)
*BOUNDARY
Velocity
*BOUNDARY, TYPE = VELOCITY
Acceleration
*BOUNDARY, TYPE = ACCELERATION
Temperature
*BOUNDARY on dof 11
Electric potential
*BOUNDARY on dof 9
It is recommended that you use only one boundary type per load collector in Engineering Solutions. If you need to use multiple boundary types in the same STEP, define each type in a separate load collector and add them to the same load step.
You can define a *BOUNDARY card on nodes/geometry or on node sets.  For Define Boundary on:, the following options are available:
Nodes or geometry
Node sets
step_mgr_boundary
The layout of the Define tab changes, based on your selection.
See Also:
Load Step: Boundary
