Engineering Solutions
2D Solid, Axisymmetric, or Gasket Elements
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The 2D solid, axisymmetric, or gasket elements option is valid for Standard.2D template or 2D models in Explicit template only.  It allows you to define the *SURFACE card by specifying edge identifiers for individual 2D solid, axisymmetric, and gasket elements.  In the graphic area, these edges are displayed by special contactsurface edge elements. Unlike, 3D solids, there is only one way to define the face identifiers for 2D solids: by picking nodes on a specific edge and sweeping through a break angle. Therefore, the Nodes on edge option is always selected.
contact_mgr_surface_tab_define_6
The 2D solid, axisymmetric, or gasket elements option has the following buttons:
Elements
Opens the Element Selector panel and allows you to pick the underlying 2D solid, axisymmetric, and gasket elements from the graphic area.  The selected elements are highlighted. The corresponding Reset button resets the selected elements.
Nodes
Opens the Node Selector panel and allows you to pick nodes from the graphic area. Two nodes from the same element must be picked to define an edge of that element. The selected nodes are highlighted. The corresponding Reset button resets the selected nodes.
Note:Several node pairs can be selected at the same time to define edges in different element.
Add
Finds all edges from the selected 2D solids that fall within a specified break angle of the edge(s) defined by nodes.  These edges are then added to the current surface and special contactsurface edge elements are created for display.
Note:You cannot add duplicate contactsurface edges for the same element in Engineering Solutions.  Therefore, the Add button does not check for duplicates and there is no Reject button.
See Also:
3D Solid or Gasket
3D Shell, Membrane, or Rigid Elements
3D solid coated with shell
3D Shell - Edge Based
Beam, Pipe, or Truss Elements
Element Set
Element Based Surface: Define Tab
