Engineering Solutions
3D Shell, Membrane, or Rigid Elements
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The 3D shell, membrane, or rigid elements option allows you to define the *SURFACE card by specifying face identifiers for individual shell, membrane, and rigid elements.  In Engineering Solutions graphics, these faces are displayed by special face elements.  These face elements have their own normals to define the SPOS and SNEG faces.  The face with normals along the underlying element normals define the SPOS faces.  In contrast, the face with opposing normals define the SNEG face.
contact_mgr_surface_tab_define_3
The 3D shell, membrane, or rigid elements option has the following buttons:
Elements
Opens the Element Selector panel and allows you to pick the underlying 3D shell, membrane, or rigid elements from the graphic area.  The selected elements are highlighted and their normals are displayed. The corresponding Reset button resets the selected elements and hides the normals.
Add
Adds the selected elements to the current surface and creates special face elements for display. It also checks for duplicate faces and displays a message if any are found. By default, SPOS faces are created.  In order to create SNEG faces, activate the Reverse check box and click Add.
Note:The Delete Face tab contains tools to find and delete duplicate faces in the current surface.
Reject
Rejects the recently added faces.
