Engineering Solutions
Analytical Rigid Surface: Adjust Normal Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
Select the following options on the Adjust Normal tab:
Display normals
Select the Display normals check box to show the normals on the display. Specify a length for the normals in the Size field. To change the size, toggle the check box to update the display.
Reverse normals:
Select one of the radio buttons to reverse the direction of the normals. You can only choose to reverse the normals of all line segments in this type of surface. Click the Reverse button to do this. When reversed, all coordinates and sequence of all the line segments will be updated.
The analytical rigid surface should be oriented so that the outward normals point toward any body of contact.
analytical_rigid_surface_adjust_normal
See Also:
Abaqus Contact Manager
