Engineering Solutions
Analytical Rigid Surface: Optional Parameters Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
analytical_rigid_surface_optional_parameters
Select the following options on the Optional Parameters tab:
Trimming of open free surface
Select to specify open free surface trimming. Then click the adjacent button to select whether to trim.
Max ratio
Select to adjust the thicknesses for surface facets in which the thickness to minimum edge or diagonal length ratio exceeds the specified value. Then type an adjustment value in the adjacent field.
Scale thickness
Select to scale all of the surface facets by a single factor. Then type the scaling factor in the adjacent field.
Region type for adaptive meshing
For surfaces defined on the boundary of an adaptive mesh domain, select to create a boundary region for the surfaces. Click the adjacent button to select the type of region.
No offset
Select for the surface to ignore midplane offsets.
No thickness
Select for the surface to ignore thicknesses. Do not select this option if the surface will be double-sided or a self-contact surface.
Fillet radius
Select to define a radius of curvature to smooth discontinuities between segments. Then type a length in the adjacent field.
See Also:
Abaqus Contact Manager
