1. | From the Menu Bar, select Data History > Section > Modify. |
or
If the Data History panel is open, select Section > Modify from the pull-down menu.
2. | In the Section to modify list, click the section to be modified. |
3. | Click ![]() |
It is possible to:
• | Modify the section name by setting a new name in the Section name field. |
• | Modify the section position (see Section plane normal). |
• | Modify the section components (see Section components). |
4. | Click Save to save the section modifications; or |
Click Cancel to cancel the section modifications.
5. | Click Close to close the menu. |
