1. | From the Menu Bar, select Data History > Section > Modify. |
or
If the Data History panel is open, select Section > Modify from the pull-down menu.
2. | In the Section to modify list, click the section to be deleted. |
3. | Click ![]() |
4. | Answer the question in the Dialog menu bar with Yes or Cancel. |
