1. | From the Menu Bar, select Mesh Editing > Part > Sheet. |
or
If the Mesh Editing tab is already open, select Part > Sheet from the pull-down menu in the upper-right corner of the tab.
2. | Select the Orientation radio button. |
3. | Click and pick a part in the graphic window. When finished, answer the question in the pop-up dialog window with Yes or Cancel. |
or
Click
to offset the part selected in the tree.
HyperCrash displays the normal of the element with red and green arrows according to the element orientation.
4. | Answer the question in the pop-up dialog window with Yes or Cancel. |
• | If Yes is selected, the orientation is automatically made. |
• | If Cancel is selected, tools are available to manually modify the element orientation: |
5. | Click to view the normal of the elements. |
6. | Click to switch picked orientation of the selected part. |
7. | Click to select an element with box selection and answer the question in the Dialog menu bar with Yes or Cancel. |
• | The default box is rectangular. |
• | Use the SHIFT key to define a polygon box. |
8. | Click to reverse the orientation of all the elements of the selected part. |
