1. | Click the switch under source solver: and select the existing source solver format. |
This is the solver format for the data you wish to transfer.
2. | Click the switch under destination solver: and select the appropriate destination format. |
This is the solver format in which to save the data.
3. | Click convert. |
In order for the convert process to work, you must have the Altair HyperMesh template appropriate to your source file loaded in the Files panel.
The Others (2.0) solver choice should be used for those solvers that use the dictionary format. All of the other solvers listed are card image solvers.
Please note this information regarding transferring thickness between solvers:
It is possible to transfer overall component thickness and individual element nodal thicknesses.
Thickness of individual components and overall component thickness defined in ANSYS Real constant table can be transferred to individual element nodal thickness for Nastran.
Thickness defined in the real constant table of ANSYS is converted to the corresponding component average thickness in Abaqus.
Component thickness defined in Abaqus is converted to corresponding component thickness in PAM CRASH.
Component thickness defined in Abaqus is converted to corresponding component thickness in ANSYS.
