Engineering Solutions
Surface Interaction Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Surface Interaction tab contains a description of the *SURFACE INTERACTION cards.  You can create, edit, review,  and delete surface interactions from this tab.
surface_interaction_define
The Surface Interaction table contains the following column:
Name
The name of the surface interaction cards in the database.
Note:
Double click on a surface interaction name in the table to open the corresponding Surface Interaction dialog.  Right-click on a name to display an option menu.
Table columns can be resized by positioning the cursor along a column border, pressing the left or right mouse button, and dragging the border to a new position.
The shift or CTRL key and a left-click can be used to select multiple items in a table.
The Surface Interaction tab contains the following buttons:
Auto
Launches the Auto Contact dialog that allows you to quickly and easily create interactions between several parts of your model.
New
Opens the Create New Surface Interaction dialog in which you enter the name of the new surface interaction.  The Create.. button in this dialog creates the surface interaction and opens the corresponding Surface Interaction dialog.
surface_interaction_create_new
Edit
Opens the Surface Interaction dialog for editing the selected surface interaction.
Review
Not active on this tab.
Delete
Deletes single or multiple surface interactions from the Surface Interaction table.
Rename
Rename the selected surface interaction.
Sync
Updates the Contact Manager with the current database.  If you manually create, update, or delete components, groups, properties, or entity sets from panels while the Contact Manager is open, click Sync to update the Contact Manager with the new changes.
Close
Closes the Contact Manager.
See Also:
Surface Interaction
Abaqus Contact Manager
