Engineering Solutions
Entity Browser
Entity Browser
This is the first topic This is the last topic No expanding text in this topic
Entity Browser
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
Use the Entity browser to easily sort and select an entity for a field on a dialog. The Entity browser is available through the … button and lists the entities of the relevant type for the selection.
ab-entity-browser
The entities are listed in a tree view. To select an entity, highlight it in the list and click OK. Use the buttons on the dialog to sort the list to more easily view the choices when there are many entities in the list. The buttons perform the following actions:
Filter
Type text in the adjacent field and click Filter to show only the entities with names that contain the text. You can use the wildcard character (*) to specify that the text can appear anywhere within the entity name. To clear the results and show all entities, right-click the Filter button.
Review
Highlights the selected entity in the model.
Sort
Lists the entities in alphabetical order. Click again to reverse the order.
OK
Selects an entity for the field on the dialog.
Cancel
Closes the Entity browser without making a selection.
