Engineering Solutions
Pre-Tension Section: Parameter Tab
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Parameter tab allows you to define optional data lines for the *PRE-TENSION SECTION card.
ab-con-man18
Check Dataline to activate all three input boxes for the first, second, and third component of the normal.  See the Abaqus Online Documentation for a detailed description of these items.
Click the Define by vector button to define the values in the input boxes by a vector. To create a vector, click the Create/Edit vector button.
Note:The NSET parameter is currently only supported on the card image.
