Engineering Solutions
Optimization Menu
Optimization Menu
Previous topic Next topic Expand/collapse all hidden text
Optimization Menu
Engineering Solutions Optimization technology is supported by Altair Altair OptiStruct. Altair OptiStruct is a finite element and multi-body dynamics software application which can be used to design and optimize structures and mechanical systems. Altair OptiStruct uses the analysis capabilities of Altair Radioss and Altair MotionSolve to compute responses for optimization. Note that Altair OptiStruct has its own complete help system that you can consult for greater detail. This chapter is only an overview of the concepts involved.
hmtoggle_plus1greyStructural Design and Optimization
Structural design tools include topology, topography and free-size optimization. Sizing, shape and free shape optimization are available for structural optimization. In the formulation of design and optimization problems, the following responses can be applied as the objective or as constraints: compliance, frequency, volume, mass, moment of inertia, center of gravity, displacement, velocity, acceleration, buckling factor, stress, strain, composite failure, force, synthetic response and external (user defined) functions. Static, inertia relief, nonlinear gap, normal modes, buckling and frequency response solutions can be included in a multi-disciplinary optimization setup.
hmtoggle_plus1greySetting Up Optimization
All of your optimization entities can be managed through three different ways; the Model browser's Optimization View, the menu bar or the panels.
The first thing you should do is start with a running model of your analysis type supported by Altair Radioss or Altair MotionSolve. From here the optimization setup is very simple process, called DRCO. Each letter is a stage in the process: defining or creating your Design space, creating your Responses, defining your Constraints and define your Objective.
See Also:
Optimization module
