Engineering Solutions
Load Step: SFILM
Load Step: SFILM
This is the first topic This is the last topic No expanding text in this topic
Load Step: SFILM
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The SFILM dialog allows you to define the *SFILM card on Abaqus surfaces (*SURFACE).  To open the dialog in the Load Step window, select SFILM from the tree and a load collector from the Load collector table.
The dialog contains three tabs:
Define
Delete
Parameter
step_mgr_sfilm
You can use Abaqus Contact Manager to create Abaqus surfaces.
See Also:
Load Collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
