Engineering Solutions
Load Step: Parameter
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Parameter option in the tree allows you to define the parameters of the *STEP card.
The supported parameters are:
Name, Amplitude, Extrapolation, Unsymmetric, Increment, Nlgeom, and Perturbation
See the Abaqus online documentation for a detailed description of these parameters.  Click Update to activate the parameters defined in the database.
step_mgr_parameter
See Also:
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
