Engineering Solutions
Load Step: FILM
Load Step: FILM
This is the first topic This is the last topic No expanding text in this topic
Load Step: FILM
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The FILM dialog allows you to define the *FILM cards on individual elements or geometry (surfaces).  You can also define the FILM on element sets.  To open this dialog in the Load Step window, select FILM from the tree and a load collector from the Load collector table.
The dialog contains three tabs:
Define
Delete
step_mgr_film_define_tab
See Also:
Load Collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
