Engineering Solutions
Load Step: DSLOAD
Load Step: DSLOAD
This is the first topic This is the last topic No expanding text in this topic
Load Step: DSLOAD
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The DSLOAD dialog allows you to define the *DSLOAD card on Abaqus surfaces (*SURFACE).  To open the dialog in the Load Step window, select DSLOAD from the tree and a Load collector from the table.
The dialog contains three tabs:
Define
Parameter
step_mgr_dsload
You can use Abaqus Contact Manager to create Abaqus surfaces.
See Also:
Load collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
