Engineering Solutions
Load Step: Analysis Procedure
This is the first topic This is the last topic No expanding text in this topic
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
The Analysis procedure option in the tree allows you to define the analysis type of the load step.  The following analysis types with the corresponding parameters and data lines are supported:
Analysis types:
Parameter:
*FREQUENCY
PROPERTY EVALUATION, EIGENSOLVER = {SUBSPACE, LANCZOS, AMS}, NORMALIZATION = {MASS, DISPLACEMENT}, RESIDUAL MODES, ACOUSTIC COUPLING, NUMBER INTERVAL, BIAS, USER BOUNDARIES
*BUCKLE
EIGENSOLVER = {SUBSPACE, LANCZOS}
*DYNAMIC
(Standard)
HAFTOL, DIRECT, DIRECT=NO STOP, SUBSPACE, ADIABATIC, ALPHA, INITIAL, NOHAF
*DYNAMIC
(Explicit)
EXPLICIT, SCALE FACTOR, ADIABATIC
FIXED TIME INCREMENTATION, DIRECT USER CONTROL, ELEMENT BY ELEMENT
IMPROVED DT METHOD = YES or NO
*HEAT TRANSFER
DELTMX, END = {PERIOD, SS}, STEADY STATE, MXDEM
*MODAL DYNAMIC
CONTINUE = YES or NO
*STATIC
ADIABATIC, FULLY PLASTIC, RIKS, STABALIZE, DIRECT, DIRECT=NO STOP, FACTOR, LONG TERM
*STEADY STATE DYNAMICS
DIRECT, SUBSPACE PROJECTION = {ALL FREQUENCIES, CONSTANT, EIGENFREQUENCY, PROPERTY CHANGE}, FREQUENCY SCALE, INTERVAL, REAL ONLY, DAMPING CHANGE, STIFFNESS CHANGE
*COUPLED TEMPERATURE-DISPLACEMENT
STEADY STATE, MAXIMUM TEMPERATURE CHANGE DELTMX
*DYNAMIC TEMPERATURE-DISPLACEMENT
(Explicit)
TIME INCRIMINATION, IMPROVED DT METHOD, SCALE FACTOR
There are two tabs for each analysis type: Parameter and Dataline. The layout of the tabs change, based on the analysis types selected.
step_mgr_analysis_procedure
See the Abaqus online documentation for a detailed description of these parameters.  Click Update to activate the optional parameter or data item selection in the database.
See Also:
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
