Engineering Solutions
Graphical Manipulator
A graphical manipulator allows you to modify specific items directly in the graphics area using interactive tools. Graphical manipulators are currently supported in the Section Cut panel and the Streamlines panel.
graph_manipulator_cfd
Streamlines graphical manipulator example
A description of the graphical manipulators available in each panel is outlined below:
Panel
Section Cut
Single Direction/Arrow
Three Directional
These graphical manipulators allow you to modify the definition of the section. Section cuts defined by a specific plane can only be adjusted by moving the base point along the normal. Other section cuts can be translated or rotated anywhere in 3D space.
Streamlines
Line
Two Directional
Three Directional
The streamline rake used to create streamlines is defined by seed nodes on a line, plane, or area. This line, plane, or area can be scaled, translated, or rotated using a manipulator specific to the rake type.
To use graphical manipulators, select them with the mouse and drag them to perform an operation. Each manipulator will have different operations available. For example, to translate a section cut along an axis, select the arrow pointing in the desired direction and drag it with the mouse.
graph_manipulator_cfd_02
Section cut graphical manipulator example
