Generate Run Matrix
The Generate Run Matrix panel allows you to edit the default run parameters and run the DOE study based on the inputs.
Directory Structure for Results
The Drop Test Manager stores all of the results in separate folders. A top level folder with the name of the CAD file is created under which the below sub folders are created.
Installation and Invocation of the Drop Test Template
In order to install/invoke on a PC, follow the below procedure:
2. | Create a folder on any local drive. This will be the template working directory. |
3. | Unzip the file using any of the zip utilities available. |
4. | Select an option where you see the following items under the main folder under the template working directory: |
• | A folder called tclincludes |
• | A file named drop_test.pmd |
• | A file named drop_test.pmt |
5. | Start a new Altair HyperMesh session with the Altair Radioss user profile. |
6. | Click Applications > Process Manager. |
7. | Under the Process Manager utility, click browse and select the file drop_test.pmt to invoke the drop test process template. |
See Also:
Drop Test Manager
