Engineering Solutions
Altair AcuSolve Reader Options
Extended nodal output: If you select No, only the standard result data is loaded into Altair HyperView, for example pressure and velocity. If you select Yes all available result data in the Altair AcuSolve result file will be loaded into Altair HyperView, for example velocity and gradients of velocity. The default value is No.
Load only the last time step: If you select Yes, only the last output result file will be loaded into Altair HyperView. For a steady state analysis with intermediate result output files, the final steady state result will be displayed in Altair HyperView. If you select No, all available result files will be loaded into Altair HyperView and can be animated and displayed individually. The default value is Yes.
See Also:
CFD Post-Processing
