The Components panel allows you to create and modify components and assign their material and section information for incremental analysis.
Note: | Mesh adaptivity is not applicable to rigid tools. |
How do I...
1. | Click component = and select the component. |
2. | Click section = and select the section. |
3. | Click materials = and select the material. |
See also
Setup
LS-DYNA User’s Manual
