Use the Rigid Link (
) option from the Mesh Editing menu to create, delete, edit, or cross reference a Rigid Link card (/RLINK).
In the Rigid Link panel, right-click to access the context menu, and make a selection from the available choices.
Note: | Selected rigid links may be turned ON or OFF in the display through the Model Browser. |
All rigid links can be turned ON or OFF using the Display Graphic objects or Mask all graphic objects icon on the main toolbar.
Create a new rigid link
1. | When you select Create New from the context menu, the /RLINK card panel appears. |
2. | Click check boxes to activate translation and rotation options, and right-click in the applicable fields for more options. |
3. | Click to expand the Skew and Support sub-menus and use the tools provided to make selections from these menus as applicable. |
4. | Click Save or Cancel when you are finished creating the card. |
