The Transformation option on the RADIOSS Tools menu lets you create, delete, edit, or cross reference a Transformation card (/TRANSFORM).
In the Transformation panel, right-click to open the context menu, and then select an option.
Create a New Transformation
1. | Select Create New from the context menu, then select from the following list: |
• | User Defined - the USER card panel appears |
• | Translation - the TRA card panel appears |
• | Rotation - the ROT card panel appears |
• | Symmetry - the SYM card panel appears |
• | Scaling - the SCA card panel appears |
2. | Click to edit fields and right-click in applicable fields for more options. |
3. | Click to expand the sub-menus and make selections from these menus as applicable. |
4. | Click Save or Cancel when you are finished creating the card. |
