The scaling menu helps you to stretch the parts.
Example:
To change the mesh of the red part to join it to the yellow part, use the Scaling menu.
By defining a direction and a scale factor, the mesh can be modified:
1. | Select the Scaling window ( ) sub-window. |
2. | Define the Scaling Center by using the following: |
• | Click and in the graphic window, pick one node. |
• | Fill in the X, Y, and Z fields. |
• | Enter a node ID in the Node Id field. |
From this point, three different options are available to define the scaling direction and the scaling factor.
Enter a factor in the three directions:
1. | Click the Factor radio button to activate it. |
2. | Fill in the X, Y, and Z fields with the Factor Value in each direction. |
3. | Click Apply Scaling as many times as necessary to apply the defined displacement. |
4. | If necessary, click the functions to undo or redo the displacement. |
5. | Click Close to close the menu. |
Enter a direction and a factor:
1. | Click the Dir./Factor radio button to activate it. |
2. | Define a direction by using one of the following: |
• | Click and in the graphic window, pick two nodes. |
• | Fill in the X, Y, and Z fields for the Vector Coordinates |
3. | Enter the scaling factor in the Factor field. |
4. | Click Apply Scaling as many times as necessary to apply the defined displacement. |
5. | If necessary, click the functions to undo or redo the displacement. |
6. | Click Close to close the menu. |
Pick a vector (the vector will define a direction and a factor):
1. | Click the From/To radio button to activate it. |
2. | Click and, in the graphic window, pick two nodes. |
4. | If necessary, click on the functions to undo or redo the displacement. |
Go to
Move
