1. | Click the Torso/Head to move the corresponding angles. |
2. | In the Torso/Head positioning part of the window, select the dummy angle to adjust. |
The selected part is highlighted in red.
Torso
Neck
Head
3. | Use the mouse to move the selected part: |
4. | Click . |
5. | In the graphic window, pick a node on the selected part (the available nodes are displayed in green) and move the mouse to rotate it. The selected part is moved along a red circle. |
6. | When finished, click Yes in the Dialog menu bar. |
• | If necessary, pick another node to move again around the same angle, or click Cancel in the Dialog menu bar. |
or
• | Set the angle in the field. |
or
• | Click to adjust the angle. |
7. | Click to save the angle setting. |
8. | If necessary, select another angle and repeat the same steps to adjust it. |
9. | Click Close to close the menu. |
Go to
Dummy Positioner
