1. | Click the Lower limbs toggle to display the corresponding page. |
2. | In the Lower limbs positioning part of the window, select the left or right leg angle to adjust: |
3. | The part of the leg that will move is highlighted in red. |
4. | Use the mouse to move the leg: |
5. | Click ![]() |
6. | In the graphic window, pick a node on the leg (the available nodes are displayed in green) and move the mouse to rotate the leg. The leg is moved along a red circle. |
7. | When finished, click Yes in the Dialog menu bar. |
• | If necessary, pick another node to move the leg around the same angle, or click Cancel in the Dialog menu bar. |
or
• | Set the angle in the field. |
or
• | Click ![]() |
8. | Click ![]() |
9. | If necessary, select another angle and repeat the same steps to adjust it. |
10. | Click Close to close the menu. |
