1. | From the Menu Bar, select LoadCase > Gravity Load > Modify. |
2. | Select gravity loads using one of the following methods: |
Button
Behavior
select all the gravity loads
pick the arrow of the gravity load in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
select gravity loads by box (use the SHIFT key to use a polygon box).
pick parts in the graphic window to select all the gravity loads applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel
select parts by box (use the SHIFT key to use a polygon box) to select all gravity loads applied to those parts.
Click the gravity load line in the listing window to select it. Several gravity loads from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys.
3. | Select only one gravity load and click for the option to do any of the following: |
• | Change the gravity load name. |
• | Modify the sensor (see Sensor). |
4. | Click to delete the selected gravity load. |
5. | Answer the question in the pop-up dialog window with Yes or Cancel. |
6. | Click Save to save the modified gravity load; or |
Click Cancel to cancel the gravity load modification.
7. | Click Close to close the menu. |
Go to
Gravity
