1. | From the Menu Bar, select LoadCase > Concentrated Load > Modify. |
2. | Select concentrated loads using one of the following methods: |
Button
Behavior
select all the concentrated loads
pick the arrow of the concentrated load in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel
select concentrated load by box (use the SHIFT key to use a polygon box)
pick parts in the graphic window to select all the concentrated load applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
select parts by box (use the SHIFT key to use a polygon box) to select all concentrated load applied to those parts
3. | Select only one concentrated load and click for the option to do any of the following: |
• | Change the concentrated load name. |
• | Modify the sensor (see Sensor). |
4. | Click to delete the selected concentrated loads. |
5. | Click Save to save the modified concentrated load; or |
Click Cancel to cancel the concentrated load modification.
6. | Click Close to close the menu. |
Go to
Concentrated Load
