1. | From the Menu Bar, select LoadCase > Added Mass > Modify. |
2. | Select added masses using one of the following methods: |
Button |
Behavior |
select all the added masses |
automatic correction of unspread masses |
pick the arrow for the added mass in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
select added masses by box (use the SHIFT key to use a polygon box). |
pick parts in the graphic window to select all the added mass applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
select parts by box (use the SHIFT key to use a polygon box) to select all added masses applied to those parts. |
Click the added mass line in the listing window to select it. Several added masses from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys. |
3. | Select only one added mass and click ![]() |
• | Change the added mass name. |
• | Select or unselect nodes or parts (see Node and part selection). |
• | Modify the added mass components (see Property). |
4. | Click ![]() |
5. | Answer the question in the pop-up dialog window with Yes or Cancel. |
6. | Click Save to save the modified added mass; or |
Click Cancel to cancel the added mass modification.
7. | Click Close to close the menu. |
