1. | From the Menu Bar, select Process > Results Mapper. |
2. | Select the Assign tab. |
3. | Click ![]() |
• | AUTOFORM format |
• | RADIOSS format |
• | PAMSTAMP format |
• | LS-DYNA format |
• | NASTRAN format |
• | Import previous session |
4. | In the new dialog window that opens, select the directory where the desired files are located in the left area (under Folders), and then click the name of the files in the right area (under Files) and select OK to load the stamping result, or select Cancel to cancel the load. |
Note: | Several files can be loaded at the same time. |
5. | Select one of the stamping results from the list. |
6. | Click ![]() |
1. | Select one of the stamping results from the list. |
2. | Click ![]() |
After merging the needed file, assign the stamping result to the crash model.
