A stiffener is a new part defined by an offset from part of an existing part's shell element.
1. | From the Menu Bar, select Mesh Editing > Part > Sheet. |
or
If the Mesh Editing tab is already open, select Part > Sheet from the pull-down menu in the tab's upper-right corner.
2. | Make sure that the Stiffner radio button is selected. |
3. | Enter a name in the New part name field and click Ok to create a new part. |
4. | Click and pick a part in the graphic window. When finished, answer the question in the pop-up dialog window with Yes or Cancel. |
or
Click
to offset a part selected in the tree.
5. | Click and pick elements in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
Or, add/remove elements by area selection:
• | Click to add elements by box selection: |
o | The default box is rectangular. |
o | Use the SHIFT key to define a polygon box. |
• | Click to remove elements by box selection: |
• | Click to add elements by circular or elliptical selection: |
o | The default shape is circular. |
o | Use the SHIFT key to define an elliptical area. |
6. | Select Keep same material to use the same material for the new part as for the reference part. |
or
Select Choose new material to set a specific material on the stiffener. The Material File window appears. In the material database, select the desired material and validate with OK.
7. | Set the thickness value in the New thickness field. |
8. | Select the Offset type and value: |
• | normal to element(s) to offset the nodes on the average normal of the neighboring elements. |
• | defined by vector to offset the nodes with a defined vector: |
o | Click and select two nodes to define the direction. |
o | Click and select an element to define the direction normal to this element. |
• | Set the offset value in the Offset field and click Ok. HyperCrash will show a preview of the stiffener. |
9. | Click Save to save the stiffener; or |
Click Cancel to cancel the stiffener creation.
10. | Click Close to close the menu. |
