Set Glue Criteria
1. | From the Menu Bar, select Connections > Glue > Criteria. |
A Glue Settings window opens.
2. | Select the appropriate criteria to check by clicking the appropriate check box. |
3. | Enter the desired values for each parameter (It is recommended to use the default values). |
4. | Click Save to keep the current settings. |
5. | To reset to the default values, click Reset. |
Check Glue Criteria
1. | From the Menu Bar, select Connections > Glue > Check. |
HyperCrash opens the window Glue / Modify. The glues which do not conform to a criteria are displayed in orange in the list.
To learn why the glue is incorrect and to modify it:
1. | Select glue in the listing window. |
2. | Click to display the glue and to open the modification menu. |
3. | Check the message in the message window to learn why the glue is incorrect (message is in green). |
5. | Click Save to save the modifications; or |
Click Cancel to cancel the modifications.
6. | Click Close to close the menu. |
See also
Glue
Export File
