1. | Select the 3D radio button. |
2. | Select the shell group: |
Button |
Behavior |
pick elements in the graphic window, then answer the question in the Dialog menu bar with Yes or Cancel. |
add/remove elements in the graphic window, then answer the question in the Dialog menu bar with Yes or Cancel. |
add elements by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove elements by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
pick parts in the graphic window, then answer the question in the Dialog menu bar with Yes or Cancel. |
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add in the selection the parts selected in the tree. |
remove from the selection the parts selected in the tree. |
clear the selection |
3. | Click ![]() |
4. | Answer the question in the pop-up dialog window with Yes or Cancel. |
The orientation of the solid elements can be checked with the Model Checker.
