1. | Select parts in the tree (see Selection List for information on how to select parts in the tree). |
2. | From the menu bar, select Quality > Check Connectivity of Tree Selection. |
3. | Under Connectivity taken into account, make a selection: |
• | Check-mark (selected): the connectivity type will be taken into account. |
• | Blank (not selected): the connectivity type will not be taken into account. |
4. | If the list of connectivity does not appear in the window, select one of the following: |
• | Click ![]() |
• | Click ![]() |
• | Click ![]() |
5. | Select parts by picking from the list of connected parts, using one of the following. |
• | Click ![]() |
• | Click ![]() |
Note: | The parts which are not connected to other parts appear in the window under the Free part subset. |
